This command configures the LACP fallback timeout value in seconds.
lacp | LACP (Link Aggregation Control Protocol). |
fallback | Allow single member port with lowest value priority to be added to the aggregator if LACP PDUs are not received within timeout. |
timeout | Timeout used to determine how long to wait for LACP PDUs before entering fallback. |
seconds | Fallback timeout in seconds. Range 0-100. |
60 seconds.
* # show lacp lag 17 detail Lag Actor Actor Partner Partner Partner Agg Actor Sys-Pri Key MAC Sys-Pri Key Count MAC -------------------------------------------------------------------------------- 17 0 0x03f9 00:00:00:00:00:00 0 0x0000 1 00:04:96:6d:55:13 Enabled : Yes LAG State : Up Unack count : 0 Wait-for-count : 0 Current timeout : Long Activity mode : Active Defaulted Action : Delete Fallback : Enabled Fallback timeout : 40 seconds Receive state : Enabled Transmit state : Enabled Minimum active : 1 Selected count : 1 Standby count : 0 LAG Id flag : Yes S.pri:0 , S.id:00:04:96:6d:55:13, K:0x03f9 T.pri:0 , T.id:00:00:00:00:00:00, L:0x0000 Port list: Member Port Rx Sel Mux Actor Partner Port Priority State Logic State Flags Port -------------------------------------------------------------------------------- 17 10 Initialize Unselected Detached A-G----- 0 18 5 Initialize Fallback Collect-Dist A-GSCD-- 1018 19 5 Idle Unselected Detached -------- 0 ================================================================================ Actor Flags: A-Activity, T-Timeout, G-Aggregation, S-Synchronization C-Collecting, D-Distributing, F-Defaulted, E-Expired
This command was first available in ExtremeXOS 21.1.
